Resets the priority for all IPv6 routes from one or all route origin types to the default values.
all | Specifies all route origins. |
blackhole | Specifies the blackhole route. |
icmp | Specifies ICMP. |
isis | Specifies IS-IS and applies only to blackhole routes installed for summary addresses. |
isis-level-1 | Specifies IS-IS Level 1 routing. |
isis-level-1-external | Specifies IS-IS Level 1 External routing. |
isis-level-2 | Specifies IS-IS Level 2 routing. |
isis-level-2-external | Specifies IS-IS Level 2 External routing. |
ospfv3-as-external | Specifies OSPF as External routing. |
ospfv3-extern1 | Specifies OSPF External 1 routing. |
ospfv3-extern2 | Specifies OSPF External 2 routing. |
ospf3-inter | Specifies OSPFInter routing. |
ospf3-intra | Specifies OSPFIntra routing. |
ripng | Specifies RIP. |
static | Specifies static routes. |
vr_name | Specifies a VR or VRF name. |
N/A.
The following table lists the default values that apply after you enter this command.
Route Origin | Priority |
Direct | 10 |
BlackHole | 50 |
Static | 1100 |
ICMP | 1200 |
OSPF3Intra | 2200 |
OSPF3Inter | 2300 |
IS-IS L1 | 2360 |
IS-IS L2 | 2370 |
RIPg | 2400 |
OSPFv3 ASExt | 3100 |
OSPFv3 Extern1 | 3200 |
OSPFv3 Extern2 | 3300 |
IS-IS L1 Ext | 3400 |
IS-IS L2 Ext | 3500 |
The following example returns the IPv6 route priority for all route origins to the default values:
unconfigure iproute ipv6 priority all
This command was first available in ExtremeXOS 12.1.2.
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
